34970A termocouple configure
Hi guys, i have a big problem here. I am using a an Agilent 34970A for acquire temperature, and using its driver for LabVIEW. Until here, thats ok, but when i change termocouple type, the vi don´t change. Example: i choose t-type, and run my vi, but the data acquired are wrong, because de vi don´t really change the termoccouple type. He is return for j-type indifferent of my choose. How i troubleshooting this?
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 1 of 21
(7,850 Views)
Hi Icaro,
you need to check the commands send to your DMM and to compare them with the ones given in the manual of your device…
Message 2 of 21
(7,842 Views)
How are you changing the type? Hopefully you are doing it by changing the constant on the main's block diagram.
Message 3 of 21
(7,838 Views)
So Dennis, am i using an Enum like control to change the type of thermocouple, but even changing the type, my daq still auto config for j-type. I try using a t-type like constant, but i dont have success.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 4 of 21
(7,832 Views)
Thanks GerdW, but how i can make it?
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 5 of 21
(7,831 Views)
Post an image of your block diagram. I've used the 34970 and the 34980 extensively without any such problem.
Message 6 of 21
(7,829 Views)
Ok, thats it 🙂
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 7 of 21
(7,826 Views)
The for loop is unnecessary as is the sequence structure. I would also recommend that you connect the functions in series and make use of the error in/out connections
Message 8 of 21
(7,821 Views)
Like it?
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 9 of 21
(7,815 Views)
Sort of. I still don't see any reason for the sequence structure but give it a try. You can also turn on NI-Trace and look at the command that is actually sent. I don't have a 34970 right now to try it.
Message 10 of 21
(7,807 Views)
