34970a + Programming + VI
Hello
I have a question about programming with LabVIEW. I have the SubVIs from Agilent, and want to connect to a VI.
Which subVIs is to use
visa open
initialize
configuration
Route open
meas temperature
visa close
I have a 4 wire RTD to mess the temperature
Agilent is 34970a
I don`t no why I have an ERROR in the ID-query.
I hope they are can me help.
thanks
Ron
(3,552 Views)
I don't know anything about the driver from Agilent. I would suggest you get the driver from NI and look at the examples. There is an advanced scan and an easy scan example that can be modified for a RTD measurement.
If you are getting an error and want help in fixing it, you need to provide the errror code/message. We can't read your mind.
(3,547 Views)
Ron2406 wrote:
Hello
visa open
initialize
configuration
Route open
meas temperature
visa close
Agilent is 34970a
thanks
Ron
Uh-oh, I don't want to sound discouraging, but if you don't know how to implement these sub-VIs you might want to read some LabVIEW tutorials on basic use and basic communication with an instrument.  We can help you here, of course, but learning these basic things before asking your questions would probably save you a lot of time by not having to go back and forth about things in the forum.  🙂
Bill
Bill
CLD
(Mid-Level minion.)
(3,536 Views)
