01-30-2019 02:35 AM - edited 01-30-2019 02:52 AM
my aim here is to be able to display all the waveform that are inputted into the 34972A channels. is it possible to use the common channel to achieve this ?
or rather should i rephrase my sentence how do i use the common channel to access other channels input waveform ?
Solved! Go to Solution.
01-30-2019 10:28 AM - edited 01-30-2019 10:38 AM
The HP/Agilent/Keysite 34970A/34972A is NOT a high speed DAQ so it will not read, measure, save, or display a waveform of any kind.
The 34972A is intended to take a high number of measurements at specific but relatively slow intervals.
It's fastest scanning rate is 250 channels/second so that means at best it could measure one channel at a sample rate of 250Hz, that makes for a pretty sad oscilloscope or waveform measurement.
01-30-2019 07:29 PM
hi can you please kindly advise me or recommend me another kind of NI device if possible.
01-31-2019 01:01 AM - edited 01-31-2019 01:04 AM
Hi soarin,
First step: write down all your requirements, starting with number of channels and samplerate.
Second step: call your local NI sales guy…
I hope you don't talk about the COM or GND connection when you write "common channel"…
01-31-2019 09:19 AM
The 3497xA is is just a fancy multimeter and when a multiplexer card is installed is has 20 differential or 40 single ended inputs depending on the card. I am guessing he was asking how to read waveforms on individual channels.
