3D Graph - How to fill certain span to certain colour?
In attachment there is example VI to create continuous updating 3D graph. My aim is to change surface colour of certain z-value span. E.g if Z-values in 3D graph are between 100 and 600 and I want change area colour when Z-value is between 250-330. This idea can be seen easily in .jpg picture. One idea might be set certain colour to certain values in color ramp but it is updating all the time even I have switched Z auto scale off.
This is some kind of area "cursor". Cursors are normally used only to one point but I need a "cursor" to one area.
Any idea how to do this kind of structure?
BR, Jim
(3,449 Views)
Starting at reply #7 in this thread you will find a discussion of a worse case example that demonstrates how you plot stuff in 3-D.
Please down load that code and review the posts.
Theoreticly everything you need is in that example.
Ben
(3,427 Views)
Hi Ben,
I checked that thread. I noticed that they have used 3D Graph ActiveX component. I need to use this "new" 3D graph component which are part of LabVIEW. Are these tips working also with that component?
BR, Jim
(3,403 Views)
SnowForest wrote:
Hi Ben,
... I need to use this "new" 3D graph component which are part of LabVIEW. Are these tips working also with that component?
BR, Jim
I can't speak to that.
The new 3d graph stuff was apperently developed in a vaccum with no interest in what the old one could do. Since I never stumbled across any good tutorials for it and an apperent lack of support for the new one, I have not investested any time in the new one. The old one still works. So its your choice, go with the old one where you have a possible solution or blaze a new trail.
Ben
(3,396 Views)
Hi Ben,
Previously I used that same component but we was have a problem in run-time environment. NI support gave us "workaround" to use this new component. I have a solution for this old 3D graph component. So I need to contact NI support again and ask them give better workaround.
Thank you very much,
BR, Jim
(3,392 Views)
