3D Graph Replacement Bug
When trying to replace, say, a 3D Graph of type 3D Surface by another type (say, 3D Contour), LV returns an error:
Of course, that is wrong, as all those XControls accept either three 2D arrays or two 1D arrays plus a single 2D array.
Manually replacing the graph (by dropping the XControl on the FP, reconnecting the wires formerly fed the first graph to the new one, things work like a charm (err, except for a bag of bugs)
Tested with the latest and greatest on a Windows XP machine.
PS: I am talking about the XControls to be found in the Modern>>Graphs>>3D Graphs palette.
(3,523 Views)
Thank you for identifying this issue with the 3-D graphs. I will go ahead and create a Corrective Action Request and notify R&D.
Regards
Arham H
(3,484 Views)
Please post the CAR number in this thread so that we can inquire about it at a later time (you guys tend to park cars by the hundreds and forget about them 🙂
Thanks.
(3,464 Views)
The CAR has been generated and the number is 415808.
Once again, Thank you for identifying potential bugs in LabVIEW.
Best Regards
Arham H
(3,449 Views)
