3D Picture: Applying Different Textures to Faces of a Cube
I would like to create a fancy splash screen that consists of 4 different images applied to vertical faces of a parallelepiped (using 3D picture controls). Periodically this parallelepiped will rotate smoothly around its vertical axis. I have two questions about it:
1. I've been able to apply one image as a texture to a parallelepiped or a cube ("as a decal"), but this image repeats itself. Is it possible to have different textures applied to different faces?
2. How can I ensure that when a face of the parallelepiped is looked at orthogonally, the picture is pixel-perfect - no resampling, no perspective?
Sergey
Message 1 of 20
(6,064 Views)
I figured out how to get rid of perspective - set AutoProjection property of the 3D picture indicator to "none". The other questions still remain: how to apply different textures to different faces of the cube and how to make them map 1 to 1 in terms of image pixels and 3D indicator pixels.
Thanks!
Sergey
Message 2 of 20
(6,057 Views)
I guess I should use a quad mesh... Sounds like a pain to program!
Message 3 of 20
(6,054 Views)
Haha! Sounds like you answered your own questions. I just wanted to let you know that I read your posts and I'm happy to help if you have more questions!
Message 4 of 20
(6,040 Views)
Where can I find an example of a quad mesh?
Ben
Message 5 of 20
(6,038 Views)
https://www.ni.com/docs/en-US/bundle/labview/page/using-meshes-to-draw-3d-objects.html
See that for a good reference on meshes.
https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-surface-appearance-of-a-3d-object.htm...
See that for information on texture application.
On top of that, make sure to consult the LabVIEW help on all the VIs you're using! They're very useful resources when you get stuck!
Let me know if that isn't specific enough or doesn't answer your question!
Message 6 of 20
(6,033 Views)
I couldn't find a particular example of a Quad Mesh in LabVIEW. It's just a Polygon Mesh (http://en.wikipedia.org/wiki/Polygon_mesh) consisting of quadrilaterals if I understand correctly. The term is indicitive of the structure of the mesh, not of a particular VI or example beyond normal mesh building and texturing.
Message 7 of 20
(6,031 Views)
Hi Kevin,
If you happen to have an example of creating a quad mesh with textures (ideally a cube), could you post it? That would save me a lot of time... If not, I guess I'll have to bite the bullet and do the grunt work myself 😞
Sergey
Message 8 of 20
(6,023 Views)
The second link I linked (https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-surface-appearance-of-a-3d-object.htm...) has a picture of a VI in it (which I, strangely, could not find in actual code form) which will texture a cube. Or was that not what you were looking for?
Message 9 of 20
(6,019 Views)
This example applies one texture to all faces of a cube, cube generation is prepackaged. If I want to apply a unique texture to each face of a cube, I'll need to do low-level programming (definition of cube vertices, etc)...
Message 10 of 20
(6,012 Views)
