3D Plot Properties Axis Format Property update bug
Tested in LV 2011, Windows XP.
If you try to change an axis format property (say Digits of Precision) and switch to another axis using the pull-down list box, the property is not updated, even though it is also not applied to the new axis.
In other words: the default precision is 2 and I want to change it to 1 for the X and Y axes.
I select the X axis, change the Digits value to 1. This applies it to axis 1. Good.
I now select the Y axis: the Digits value does NOT change (it stays 1) but the Y axis precision does NOT change either (it stays 2). Not good.
You have to actually edit the Digits field an press enter to update the value ON THE GRAPH.
There might be some similar bugs in other properties.
(2,971 Views)
Hi X.!
Thanks for posting your find. I would love to take a look at this behavior. There are multiple 3D graph property dialogs depending on your implementation. I've looked at three examples and they each have a slightly different menu options under format properties. Can you point to or post an example that duplicates the behavior?
Best Regards,
Andrew S
Application Engineering Specialist
(2,961 Views)
That's odd. It appears I posted this question twice! Maybe some glitch with my browser?
Anyhow, thanks for asking but as discussed here I found this issue to not be reproducible.
(2,949 Views)
Oh, ok. Thanks for the link.
Andrew S
(2,939 Views)
