3D Stem Graph String-based Axes
When using 3D Stem Plots and real-world data, I successfully generate a 3D Graph. However, I was wondering if it is possible to customize the X and Y axis values with strings rather than numbers. I still want the Z-Axis to be a numerical intensity, but rather than having the X and Y values be an integer that I have to define in a note, I would like to make these values show strings.
My VI (attached) involves sample baseball batting/running statistics for each position (except pitcher).
Thanks in advanced,
T16626
"Whether you think you can or can't, you're right."
~Henry Ford
(4,648 Views)
If I understood you correctly, you are simply wanting to add labels to your graph.  The following link goes over customizing graphs:
https://www.ni.com/docs/en-US/bundle/labview/page/customizing-graphs-and-charts.html
Does that information answer your question?
Shane C
(4,592 Views)
Thanks Shane, but this isn't exactly what I was asking. Maybe I convoluted my question.
Imagine a 2 dimensional vertical bar graph.
The Y-Axis shows intensity, while the X-Axis is marked with what each bar refers to.
So let's say we're looking at a pizza parlor. They graph how many cheese, pepperoni, and sausage pizzas are sold on average per week.
Cheese---25 per week
Pepperoni---20 per week
Sausage---18 per week
so the X-Axis would have 3 tick marks, one designating each bar (cheese, pepperoni, and sausage) and the Y-Axis would be marked from 0 to 25, and the bars would reach 25, 20, and 18 units high respectively.
Here's a visualization of an ideal X-Axis (from Wikipedia's page "Bar Chart"): http://upload.wikimedia.org/wikipedia/commons/3/35/Incarceration_Rates_Worldwide_ZP.svg
What I am looking to do is find a way to create these custom ticks on the X-Axis instead of writing off to the side:
"1 refers to cheese, 2 refers to pepperoni, and 3 refers to sausage"
Please note that my goal is to apply this concept to a 3-D graph, rather than a 2-D graph.
Hope this clarifies my question.
~T16626
~Henry Ford
(4,588 Views)
I am sorry for the confusion there.  I have put together a simple example that modifies the tick marks on a 3D graph.  I only modified one of the axis, but you should be able to expand upon this code for your particular application.
Does this better answer your question?
Shane C
(4,568 Views)
Accepted by topic author T16626
My code in the previous post was for LabVIEW 2013.   I have included here a LabVIEW 2011 version of the code.  If another version is needed, I will see if I can create one.
Shane C
(4,567 Views)
