08-23-2013 05:53 PM
I will need to increase the lengths of inputs 'substantially' using the 3D Surface Plot.vi. Using the example found from the help 'Find Examples' (see attached), can anyone tell me where to start? The example is using '40' as a length, I may need 6 or 8 figures?
08-26-2013 11:27 AM
Hi Newton,
Could you share the code and also, could you specify a little more about what you mean by needing 6-8 figures? Do you mean 6-8 plots on the same graph? Or 6-8 different graphs?
