3D data interpolation
My data set consists of an irregularly spaced X-Y location table with very fine resolution in the vertical (Z) axis. I need to interpolate the data in the X and Y directions to make a smooth, usable plot.
Anyone out there done this in LV?
(3,186 Views)
Ah ! That's a nice challenge !!!
For a simple linear interpolation, the difficulty is to locate the best triangle surrounding the point where you want to interpolate the Z value. This is not a trivial problem, but some algorithms are quite efficient at that (one is used internally by the 3D graph).
If you have only a few X and Y (less than about 100, and homogeneously dispersed...), there is a nice vi, named "Tripolation.vi", written by Koji Ohashi. Not optimized, but enough for basic computations.
If you ever find a solution for large data sets, don't forget to tell me !
CC
Chilly Charly    (aka CC)
(3,180 Views)
