3D floating bar chart / Gantt chart / candlestick type plot
Hi all,
Can I create a plot like the attachment with LabView?
The best I can describe it is a 3d Floating bar chart / Gantt chart or a 3d Candlestick chart
Phill
(3,045 Views)
I wouldn't want to say "No", but I suspect it will be a lot of work.  It might be more appropriate to use LabVIEW to gather/generate/process the data and to export the data in a file appropriate for whatever Plotting Routine produced that rather nice and interesting picture.  Note that you might be able to specify axis names, colors, etc. that the Super Neat Plotting Routine needs, so it acts like a Fancy Rear End (hmm, that came out wrong -- I was going to call it a "Front End", but LabVIEW is acting as the "Front End" for the Super Neat Plotting Routine, so that makes the SNPR the "Rear End" for LabVIEW -- maybe "Back End" sounds better, but has yet another meaning ...).
Bob Schor
(3,013 Views)
A 3D picture control would work just fine, but requires work. For simpler needs, don't forget this toolkit.
(3,005 Views)
Thanks for the advice! I'll look into these suggestions
(2,990 Views)
