3D graph => crash
I use labview 5.1.1 on a PIII (winNT SP6).
Everytime I use a 3D graph WinNT crash (blue screen).
Do you know why ?
(3,173 Views)
Nicolas Weiss wrote in message
news:39dc3b38@epflnews.epfl.ch...
> Do you know why ?
Works fine here on a similar setup. Try changing your "display type" to "VGA
Compatible Display Adapter" in the NT control panels and see if the 3D
graphs still cause crashes; if everything works fine then you have a problem
in your display driver settings or version and need to do some fiddling on
that front.
(3,173 Views)
> Do you know why ?
The 3D graph uses OpenGL. You might want to try out different
configurations of your video driver and your OpenGL drivers.
Greg McKaskle
(3,173 Views)
