3D graph
Hello.
I would like to modify my 3D curve graph. What I want to do is divide the two regions of the graph area into 2 different colours. Can this be done?
Another modification I would like to perform is to replace the 3D box that the line is plotted on, and instead display a 3D representation or model of the human body, in which the line is plotted within it. Does anyone know of anyway in which this can be done?
(812 Views)
As a first step, attach a simplified version of your VI to avoid ambiguities.
I am not aware of a "3D curve graph". Are you talking about the "3D line graph" or something else?
You can have multiple plots, each with a different color. You can use a parametric surface graph to display random surfaces, even change the opacity.
For more complicated scenarios, you can use a 3D image and built everything explicitly (you can even import ASE, STL, VRML geometries from a file).
(738 Views)
