3D graphs
I would like to know whether it is possible to plot more than one plot in a 3D waveform graph. If so, kindly include a sample code.
Thank you
(3,654 Views)
What version of LV are you using? I think you are talking about the 3D Surface Graph. Is that correct?
Norbert
Message Edited by Norbert B on 03-10-2009 04:58 AM
Norbert
Expert: Geometry
(3,649 Views)
hello,
Thank you but I already firgured it.
Thanx
(3,643 Views)
I have a number of ASCII files, containing a matrix of energy values. Each file was creates for different z value, so eventually, I'm having XY slices of a 3D area. I need to build a 3D graph containing all of them, one above the other, by there z values. I think it should be done by using various number of plots on the same 3D graph. Can you help me with that?
I'm using, Labview 8.2.1 and Labview 8.5.
Thanks in advance,
Yogev.
(3,599 Views)
Take a look at this thread starting at post #7.
If you still have trouble after looking atht eh example I posted there...
Start a new thread and include enough code and sample data that we can see what you are attempting.
Have fun!
Ben
(3,578 Views)
