3D picture control show the zoomed stl "model aircraft"
I've tried adding a STL model file of a "A380 aircraft" to the 3D picture,but i did not get the image i want.The outcome i getThe outcome i get
block diagramblock diagramThe plane i uploadedThe plane i uploaded
I want the camera  to be zoom out,so i can see the full image of the aircraft.
I've tried testing out with some of the functions,but did not get what i want.
Any help is appreciated 🙂
I am using labview robotics 2015,version 15.0.1.I am using arduino to input data from the sensor altIMU 10-V5.
(3,687 Views)
Without that model file, all we can say you're doing something wrong...
(3,637 Views)
Accepted by topic author CQL
At edit time, right-click the 3D picture control and select: Auto Projection -> perspective
Then, right-click it again and select: Camera controller -> Spherical.
When running, press shift, left-click and move the mouse up to zoom in, and down to zoom out.
More info at: zone.ni.com/reference/en-XX/help/371361P-01/lvhowto/3d_configure_camera/
Marc Dubois
(3,619 Views)
