3D picture control with basic camera control
Hi
I am very new in labview and especially in the 3D picture control. I must agree that it is a very good tool. I try out some examples and went through some tutorials but i still can't figure out how to create the camera controller as it is like the one in the RobotArm.vi in the example. It can "zoom" with a <shift> & drag in the picture area and "pan" with a "Crtl" & drag in the picture are tool. Can some pros give me some guidances in it?
Thank a lot.
(3,117 Views)
Assuming you mean the control, just right click and select Camera Controller -> Spherical.  If you are using the Scene Window, then set the property Camera Controller Type to Spherical.
Jeff Peters
LabVIEW R & D
(3,107 Views)
Thank Jeff
I finally figure it with the help of your advice. A thousand Thank
Ah Ya
(3,097 Views)
