3D picture control
Hi
I am working on a project with 3D picture control.  I know how to take 2 objects, add them together and translate/rotate them.  I have 2 objects: object A and object B.  I am trying make a rotation of object B relative to object A.  I can make this rotation from rest to desired position   However, I am unable to figure out how to make a continuous movement from rest to desired position.
somebody help?
(3,060 Views)
To clarify your question, are you trying to produce an animation-like, continuous movement to translate a 3D picture control to a desired position?
In other words, I am trying to simplify your question. Are you able to produce a continuous movement (animation) of a single object?
So if we could produce a continuous movement of a single 3D picture control, could you then possibly extend this concept to your relative positioning scheme?
Thank you,
Eric
(3,017 Views)
These community examples may help you out although I have not used them myself:
Solar System with 3D Picture Control:
https://decibel.ni.com/content/docs/DOC-2109
Robotics Simulation Utility using 3D Picture Control:
https://decibel.ni.com/content/docs/DOC-2430
(3,006 Views)
