3D plane using four points.
Can I build a 3d PLANE using 4 points with Labview 6i and how?
(3,440 Views)
There's a 3D surface example called "Flucuating Sine Wave.vi" that should point you in the right direction. What exactly are you wanting to plot?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,440 Views)
Hi Mikeporter, thank you very much for your help. In which vi library can I find the "Fluctuating Sine Wave.vi"? I would actually like to represent a pyramid in 3 dimensions.
Summer
(3,440 Views)
In LabVIEW go to the examples browser and click on Fundamentals, then Graphing and finally the first selection is 3D surface plot.
Mike...
LabVIEW Champion
(3,440 Views)
Thank you very much for your help.
Summer
(3,440 Views)
