3D plot - Stewart platform
I want to make 3D plot to Stewart platform (like on the left side on the picture 1.
I made a program which display points on 3D plot (picture 3), but I also need :
1. connect with lines points which form the bottom and top platform,
2. connect with lines 6 actuators in points on the platforms. Top platform should change position when i change the lenghts of actuators.
I checked many examples, but i couldn't find anything what i need, so I'm writing here to ask you about it.
(3,406 Views)
You'll have to order your 3D Graph X, Y and Z arrays to sequence through your points in the right order and use the 3D Graph Properties (right click on your graph) to configure your points and lines appearance (color, dash etc..)
(3,276 Views)
