3D plots
It appears that 3D plots are not supported on the Linux version of LabVIEW (7.1) for some reason. I have the results of an experiment that are a function of two variables. Is it possible to use an intensity chart to show these ? My array input is :
x1,y1,result11
x1,y2,result12 etc.
An example would be helpful.
(2,913 Views)
Intensity graphs work best if the data forms a regular grid. In this case you would just graph the 2D array of result values and adjust x0 and dx of the axes according to your x and y values.
If you have arbitrarily located values, you could setup a 2D array of suitable size (filled with e.g. -INF), then use scaled x and y values as index to replace certain elements with your corresponding result values.
(2,904 Views)
Here's a simple example (7.1).
Message Edited by altenbach on 10-12-2006 05:08 PM
(2,904 Views)
