3D surface graph in Linux
HI,
I would like to know if there is a away of simulating 3D surfaces graphs on Linux.
In particular, I do simulate 3D surfaces by moving the origin and plotting a new curve without deleting the previous ones, but I would like to plot the 3 coordinates, not only x and y.
(5,484 Views)
As you may know, the 3D graph object in LabVIEW uses ActiveX, which is not supported in Linux but you have a option:
Have you tried using the LabVIEW 3D picture Control Toolkit. Although it's not officially supported by National Instruments, you can download and use it in any existing LabVIEW platform, using the OpenG package provided on the link below.
http://zone.ni.com/devzone/conceptd.nsf/webmain/9672f024704de89086256ed100620a56
There are also some Discussions on this as well.
Andre Pereira
Applications Engineering
(5,467 Views)
Thanks André,
I am going to install and test it.
Bye for now,
Rogério
(5,461 Views)
I've tryed it, but felt like a dumb, since I couldn't do the simpliest thing:
-Given a 3D array, plot it!!!!
Does someone has a simple example like this?
(5,449 Views)
Not being able to take advantage of the stuff that runs unders W.... complicates this quite a bit!
In post #38 of this thread on LAVA
http://forums.lavag.org/index.php?showtopic=3046&hl=irene&st=30
has some examples I managed to produce for the 3d Picture control.
You would have to start with that or something like and work your way up.
4-D graphing would be possible by defining a custom skin but it appears you loose lighting effects if you go with custom skins.
I don't even want to think about transparency......
Keep us posted on how you solve this challenge.
Ben
(5,441 Views)
Dear Ben,
thanks for your promptly reply. I am analysing your example already. I thought of  drawing hundreds of small cones, since my surface is actually made of hundreds of FFT peaks alltogheter. But I have to face another problem: how to plot the scales?
Thanks anyway, life with LV under Linux isn't easy...
(5,429 Views)
I've managed to simulate a surface, but, besides normalizing  (I have values like 6789.90, 0.0897, 128.07 in each of the 3 columns), and having no scales, it became too slow.
(5,422 Views)
