3D surface plot with two vi's open
Hey Guys,
I am wondering if someone has insight on this seemingly bug, or buffer issue - this problem i'm having. I am plotting a 3D Surface plot, and I have two vi's im working on with a 3D surface plot. When i have both VI's open, the 3D Surface does not plot on either VI when i run it. I can only get it to plot if i close both VI's and open just one of them.
The other thing i noticed with the same VI's, is that when i tried to subvi out the 3D surface plotting in one of the VI's, then the 3D Surface plotting would stop working also (i am guessing because labview has to relate 2 vi's with a 3D surface plot again? even though only one is open..)
I am using Labview 7 by the way, hopefully that doesnt make the huge difference. I am looking for some general feedback but since the search didn't give me any results then this might not be a known problem. Let me know if you want me to post the vi file(s) 🙂
thanks,
Marko
Message 1 of 10
(4,272 Views)
Hi Marko,
Does the following KnowledgeBase article address the issue?
3D Surface Graph Does Not Appear in a Subpanel Control in LabVIEW
If not, could you please post your VIs so that I can reproduce the issue quickly?  Thanks!
Message 2 of 10
(4,235 Views)
I don't achieve to see 3D plot into my subpanel....
Can you help me?
Message 3 of 10
(4,000 Views)
Can you help me?
If you post screen shots of your code and FP I may be able to help.
Ben
Message 4 of 10
(3,981 Views)
This is the screen shot.
Thank you
Using LV10/XP
Message 5 of 10
(3,975 Views)
Thank you
Using LV10/XP
If your video drivers are up to date and the hardware acceleartion does not help... this smells like a bug.
Try "jiggling the handle" by using an invoke node Get Image (unbunlde something from the image data to ensure it executes).
But that is only a guess and an attempt to help.
Ben
Message 6 of 10
(3,970 Views)
Hi vicens, Here is what I saw when running your Main.vi for the first time. Some ideas may help you: 1) Can you see the 3D plot by running your "SubPanel - Plot1.vi" alone? If yes, you do not have problem on video card. 2) When you run Main.vi, did you open the "SubPanel - Plot1.vi" front panel? If yes, close the "SubPanel - Plot1.vi" front panel. SubPanel can not embed VI with its panel opened.
Message 7 of 10
(3,948 Views)
Message 8 of 10
(3,946 Views)
Hi Vicens,
Can you please try the following method to call your subVI to the sub panel?
The info is available in the file attached.
Do not close the reference of the subVI until you are finished with the subVI.
Into the pursuit...
Maverick
Message 9 of 10
(3,930 Views)
Hi guys,
The method proposed by Maverick works good. I think the problem was at "close reference".
Thank you very much.
Message 10 of 10
(3,912 Views)
