3DES DLL labview
Hi!
I need to do a 3DES algorithm in LabView in order to achieve an RFID Authentication.
Now i decided to take the 3DES algorithm from cryptopp (www.cryptopp.com).
There the 3DES algorithm is stored as a DLL file.
Now my question:
Can i use this DLL file in LabView in order to make the authentication?
KR
Markus
(3,356 Views)
It is possible for you to use DLL files in LabVIEW. You have a Call Library Function Node which can be used for it.
I would advise you to take a look at those documents / example:
* Calling C/C++ DLLs from LabVIEW :
https://forums.ni.com/t5/Developer-Center-Resources/Calling-C-C-DLLs-from-LabVIEW/ta-p/3522488
* There are couple examples VI in the LabVIEW example database. I would advise you take a fist look at the ground one called Call DLL.vi . To find it, open a blank VI in LabVIEW and browse Help => Find Example => Search and write DLLs. It should appear in the right panel along with other examples which might also be useful for you.
* There is a quite detailed documentation on this topic in LabVIEW. From a VI, you should browse Help => LabVIEW Help => Fundamentals => Calling code written in text-based programming languages. From that point, all the sub-topics are related to your question.
Regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,308 Views)
