3d Curve: Interpolate points and Add a diameter
Hello everyone.
I have a 3D curve that plots an array of X, Y, and Z values. There are, however, two problems that I have with my plot:
1) I want to fit a polynomial to the "curve" (which at the moment, is of course a series of lines with sharp corners). How does one go about fitting a polynomial to a 3d array of points?
2) I want to add a diameter to my 3d curve. If you imagine that my plot looks like a tree branch, I would like for that tree branch to have some known diameter. At the moment I just have to thicken the line depth on the 3d Curve options, but of course this is insufficient and looks poor. I assume that I may need another type of 3D graph for this, but I'm not sure where to start.
Thank you!
(3,543 Views)
ap8888,
Post a data sample and possibly the graphing portion of your vi. and you will get a better response, probably involving the CWPLOT3D.
I'm not the only one that likes to play with dataSmiley Very Happy  -SS
(3,532 Views)
Sure.
This VI, of course, is actually a subVI in my larger program. All of the values, particularly the "normals" are constantly changing, and hence the curve changes as well.
(3,525 Views)
You could spline each dimension as a function of index and then interpolate with more points. Here's a rough example.
(3,502 Views)
Thank you altenbach for your response.
May I ask, however, what the first 3dCurve VI does? I don't understand what it's for when all the interpolated points are passed to the second 3dCurve VI. Also, how do make the red-points appear? Does this perhaps have something to do with the first 3dCurve?
(3,469 Views)
The graph shows two datasets.
  1. The raw data as red points
  2. the interpolated data as a line.
If you only want to show the interpolated data, you don't need (1), but how else would you test that the algorithm actually works? 😉
To change the plot styles, right-click the graph and select "CWGraph3D...properties...".
You see that plot-1 has red dots and plot-2 has green lines. Modify as needed.
Message Edited by altenbach on 07-31-2008 09:34 AM
(3,450 Views)
Yes, you should go with the 3D picture control. Maybe you can use a series of cylinders, for example.
(3,446 Views)
