3d FFT in Labview
Hi All,
I would like to do 3d FFT in Lab View. Does any one have a code for
that.
I couldn't find a Lab view code for it. Also, I tried to use a Matlab
script, but Lab View doesn't support 3d data flow in to it.
By the way I am using Lab View 8.2 and Matlab 6.5
Vinay.
(3,706 Views)
Hi Vinay,
Could you please include the VI along with the script you are trying to run? Could you please also include a screenshot of the error message you are getting? I will be curious to further investigate your issue.
Kalin T.
(3,670 Views)
Vinay,
Please include detailed explanation on how to run your VI as well and what each section of your code is doing.
Thank you!
Kalin T.
(3,668 Views)
FFTs are separable, so you can simply do a 1D FFT on each dimension in turn - even faster might be a 2D FFT followed by a 1D FFT.
Message Edited by GregS on 03-19-2007 08:46 PM
(3,661 Views)
