3d Mesh Multiplot
Hi guys,
I'm using Labview 11 and I struggle plotting multiple (x,y,z) Signals in in ONE 3d Mesh Plot. I've found the following post: http://forums.ni.com/t5/LabVIEW/3D-multiplot-mesh/m-p/129413/highlight/true#M77824 but the VI is written for LV 5 and therefore I can't open it. Do you know any solution for that problem?
Greetings,
Stephan
(2,874 Views)
(2,872 Views)
Also check out this thread:
click
Apparently you can just call the Plot helper.vi as often as you need to create as many meshes as you need.
regards
Remember Cunningham's Law
(2,843 Views)
