3d Surface plot in 2013 - Z axis range input or property node doesn't get updated on the graph
I point the problem to the  ( 3D_Plot.lvclass.graph Update.vi).
Can someone confirm this?
(3,841 Views)
I suspect the issue is that autoscale is still enabled.  I "recreated" your issue until I turned autoscaling off. Smiley Happy
(3,815 Views)
I made sure that was the case.
Maybe I'm missing an update.
I'll run the updater and see.
(3,790 Views)
This works for me.  If this is not what you're doing, or if this does not work for you, please provide more details.
(3,761 Views)
