3d curve error 97
Can you post a screenshot or even copy the text of your error message?
Eirikur Runarsson
Message 11 of 17
(2,040 Views)
Message 12 of 17
(2,032 Views)
Hi Bjarne,
The function you are trying to access is not supported in Labview 2009 64-bit:
Some of the ActiveX components are not supported by 64-bit systems. LabVIEW cannot load a 32-bit ActiveX object into an ActiveX container in 64-bit LabVIEW because a 64-bit process cannot load a 32-bit process. To work around the problem, you can install LabView 32-bit on a 64-bit machine.
I presume the VI is imported from a 32-bit system or Labivew 2009 32-bit running on a 64-bit system. Please try to get a copy of Labview 2009 32-bit and try run ths VI. I have attached a screen dump of how it looks on my Windows 7 64-bit sytem running Labview 2009 32-bit.
Please let me know if this helps.
Thanks!
Message Edited by Morini on 02-22-2010 10:13 AM
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
Message 13 of 17
(2,011 Views)
Actually I builded that VI in LabVIEW 64bit 🙂 Is it possible to have both LabVIEW 32bit and 64bit at the same computer?
Message 14 of 17
(2,003 Views)
Yes, it is possible to have Labview 2009 32-bit and 64-bit versions installed on your 64-bit system.
Dennis Morini
Message 15 of 17
(1,998 Views)
Ok, thanks Ill try to install 32bit to, and will let you know how it works out 🙂
Message 16 of 17
(1,997 Views)
Accepted by topic author BjarneDK
Well, I just installed LabVIEW 2009 32bit on my 64bit Windows 7, and the to graphs runs just fine now. Why it dosnt work on 64bit, I dont know, but for now 32bit, is fine for me.
Thanks for your time and help 🙂
Message 17 of 17
(1,980 Views)
