3d graph Diadem
Please inform me if it is possible to set the length of the axis of a 3d graph on a Diadem report.
Particularly I'd like to keep fixed the rotation of the graph and spread the x or the y axis
Best regard
Marco Milan
(3,336 Views)
Hi Marco,
If you choose manual scaling for the axis in the 3D diagram dialog at axis parameter you can modifiy the size. In the menu axissystem you can choose the angle for the rotation of the 3D diagram. All the information are for DIAdem 11.
I hope it helps you out. Feel free to ask again if you have any other questions
Regards
TomBaum
(3,312 Views)
Thanks TomBaum,
 Actually my problem is to define the length of the axis one respect to the others (matter of layout), not the scale.For example I’d like to have a 3D graph with X-axis length = 10Y-axis length= 50
Z-axis length = 15
 Regards Marco
(3,290 Views)
Hi Marco,
there is no direct way to set the length of an axis. The only way to define is to set the begin and end. What you can do is to use the position of the diagram and set the size this way,  but you have  choose scale not relative for the layout parameter.
Regards
TomBaum
(3,270 Views)
