3d open, square tank control for SCADA HMI
I am in need of a 3d tank control(basically a cube) for a DSC app and cannot find one anywhere that is both open and square. I've had limited success with the control editor and thought I would ask around before developing an ActiveX control. Any suggestions?
ST
(4,111 Views)
At present, we do not have a 3d tank control that is both open and square. You will probably need to create an Active X control, unless you can find one on the web that was created by another company.
Sincerely,
Green Rives
(4,111 Views)
if you did write an activeX Control, could i get a copy ?
(4,111 Views)
