3d planar surface bending
Hi ,
I am a beginner in labview programming. I Intend to load a planar surface in a 3d graph and visualise bending angle of the planar surface along an axis on the surface(for example...10, 30... 90 degrees etc.). In a practical scenario, it can be considered as a graphical simulation of a flex sensor placed on a bending beam.
I tried finding some examples but cudn't find any useful links.
As I am a beginner, request you to guide me in the best possible way.
Thank you soo much for your time!!!
(1,534 Views)
Check out the Sensor Mapping Express VI which maps real-world data onto a 3D model.
If you have the Advanced Signal Processing Toolkit, you can also check out this example: C:\Program Files\National Instruments\LabVIEW 2021\examples\Time Series Analysis\TSAApplications\Modal Analysis of a Plate.vi
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(1,477 Views)
