3d surface plotting in Labview (Mac version)
I would like to be able to do 3 d surface graph on as discussed in Document ID: 27GI5SG4. It appears that this works only in the Windows version of Labview. Is this function going to be ported to the Mac version or is there another way to produce the same effect.
(2,876 Views)
The 3d graphs for LabVIEW are based on ActiveX technology so they are only good for the Windows environment. I'm not aware of anything in LabVIEW that will produce similar results on the Macintosh. You may look at displaying your data in an intensity graph - it would still give you the ability to display 3 dimensions.
(2,876 Views)
