4.0.1 to 8.6
I have some old VI's which I need to open but the file format is too old.  I am currently using Labview 8.6 and teh VI's I want to open are from Labview 4.0.1.  Does anyone know of a file converter which I can use to update these VI's.
Matt.
(3,263 Views)
Hi Matt,
One way would be for someone to open it in a version that still supported it and is supported by LV8.6.
Dunno if that's possible, but the best you can do is to post your old VI's and hope someone can still open it.
At least that i know, there's no file converter available.
TN
Currently using LV 8.5
logo
(3,256 Views)
Ok I may be able to do that at my end but I can't gain access to the necessary computer for a while.
Is there no file converter program available for me to use to do this???
Matt.
(3,254 Views)
Dunno if this will helps, because i couldn't see the link, but that a look here.
TN
logo
(3,253 Views)
Thanks, for the help. I'll have to use the computer with 8 to convert these files.
Thanks for the help,
Matt.
(3,250 Views)
Hey Gilgad2000 (good profile name, by the way),
I wanted to pass on a couple of very useful KBs and tutorials.
How to Upgrade or Revert a VI to a Different Version of LabVIEW
http://zone.ni.com/devzone/cda/tut/p/id/8387
Also, if you are converting a large number of files the following KB could save you time and faff Robot wink
A single file or an entire directory can be selected for mass compile and the items will be automatically opened in the new version, saved, and then closed
What Does Mass Compile Do in LabVIEW?
http://digital.ni.com/public.nsf/allkb/654877E62A97B72986256C95006F9B24?OpenDocument
I hope that was useful,
Best wishes
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,189 Views)
