4 analog signal to read
Hai crossrulz,
Thanks for the quick example. But what I want to do was to give the user the freedom to control the 4 physical channel. Then the program would display the 4 signals from each channel signal in 4 seperate indicator where each signal enters the respective formula block. Here I got something I want to try out but I won't be able to do so until next Monday bcoz I don't have the hardware with me. Could u take a look at the code and comment if it would work or not? Perhaps you have another idea on how to do dis?
Newbie92
Message 11 of 13
(892 Views)
Hi Newbie,
But I want to do was to give the user the freedom to control the 4 physical channel.
You still can do this while using just one DAQmx task for those 4 channels: apply different settings to each channel…
Then tthe program would display the 4 from each channel signal in 4 seperate indicator where each signal enters the respective formula block.
You still can do this while using just one DAQmx task for those 4 channels: use IndexArray on the result of DAQmxRead…
Edit:
- After looking at your edited image I recommend to stay away from ExpressVI functions. Use plain LabVIEW/G functions!
- You could apply scaling to each DAQmx channel so you would receive scaled values from DAQmxRead (for "simple" scaling functions)!
Message 12 of 13
(884 Views)
hai GerdW,
Thanks for the advice. Does it looks something like this? I don't have the tools to ensure it would run properly with my cDAQ rite now though. Smiley Sad
Newbie92
Message 13 of 13
(873 Views)
