4 position switch, position 0 spring loaded to pos 1
Hi
I need a switch, four position, 0 - 1 - 2 - 3 and the default (home) is 1. If
0 is selected, it will stay there a finite amount of time (under timer
control) and return to the default, 1, position.
any suggestions... I took the basic 1 & 2 course, i seem to remember there was
a sequence control similar to this but i can't find the data on it.
thanks
ken
(2,755 Views)
Ken,
I emailed you an example. If you want, go to www.ni.com and search for
Labview switch, and one of the articles shows how to create a 3 position
switch. It is easily modified for a 4 position. Check it out. That's
how I created the one I sent you.
Mark
In article ,
ken5901@go.com (Ken) wrote:
> Hi
is 1. If
there was
> thanks
> ken
Sent via Deja.com http://www.
deja.com/
Before you buy.
(2,755 Views)
