4 to 16 line decoder - is there an easier way in Labview?
CD41515 4 bit to one of 16 output decoder. Is there an easy way without drawing a full digital schematic?
I need to decode a number (or 4 bit array) to a 1 of 10-16 indicator to show DAQ channel output activity.
Any clues?
Barry
barry
Message 1 of 12
(6,364 Views)
is this what you want?
Software developer
www.mcm-electronics.com
PORTUGAL
Message 2 of 12
(6,358 Views)
What version of LV are you running?
Message 3 of 12
(6,347 Views)
Building on the previous reply ...
A quick approach:
Build the four booleans into an array then convert the array to a numeric.
Use the numeric to drive a case structure with 16 cases that have 16 boolean outputs.
Another way:
Use the output to drive the index of a "replace array subset' for an array of 16 false booleans and replace with a True.
Use Index array sized up for 16 outputs. Done.
Ben
Message 4 of 12
(6,344 Views)
LV 8.5
Below is what I have so far, just seems kinda cumbersome but it will fit into the 20 I/O connector I guess
barry
Message 5 of 12
(6,339 Views)
Simplest way I know.
P.S.  You could also take the output of this and convert to cluster for front panel display.
Message Edited by centerbolt on 04-03-2008 01:44 PM
Message 6 of 12
(6,333 Views)
Centerbolt posted
Maybe I am confused but I thought a 4-to-16 accepte four bits and returned 16 bits were only ONE of the returned lines was true at any time.
Ben
Message 7 of 12
(6,325 Views)
Ben,
If you convert the integer 1 to 16bit binary there is only one bit set to a one.  All the rotate does is move that one to the right bit position.
Here is working vi.
Message 8 of 12
(6,310 Views)
Here is an image that will make more sense from a bit sense.
Message 9 of 12
(6,299 Views)
Thanks centerbolt, that is slick and much better than the enclosed. LOL
barry
Message 10 of 12
(6,298 Views)
