4-wire resistance measurement with 3706 DMM using 3721-ST plug-in card
I am new to labview and trying to get a 4-wire resistance measuremnt . I am kooking for an example program to get a 4-wire resistance measurement using a 3721-ST card on a 3706 Keithley DMM. I have one program where I always get error -1074000000. Thanks a lot for your inputs.
Best,
Chander
(2,738 Views)
As you should be able to determine with Help>Explain Error, it's an instrument error query failure. See if you can run the error query in MAX.
You did not specify where you got the driver or attach the code. The only driver I found was from Keithley. If this is the driver you are using, you should ask them about their code.
(2,729 Views)
