475 Convectron Automated Measurements in Labview
I am trying to acquire automated pressure measurements from a MKS 475 convectron gauge controller using rs-232 interface. Will this only require the basic visa serial functions to do?
(1,787 Views)
Quite probably!  But you are the one with the Manual -- what does it say about how to connect it to a PC?  Do you need a true RS-232 (DB-9 or DB-15) "port" on your PC?  Does it use a USB connector?
I would suggest getting appropriate hardware (cable, possible Serial-to-USB adapter) to connect your MKS 475 to a port on your PC.  Then open MAX, and see if it can "see" your device.  Assuming it can, you can use MAX to set Baud Rate and other RS-232 parameters and then open a Test Panel and try communicating with your device.
If you can "do it in MAX", you should be able to write the (simple) LabVIEW code to "do it in LabVIEW".
Bob Schor
(1,770 Views)
I am going to use a male to female rs-232 cable and I will need to use a rs-232 to usb adaptor because I have another device that is utilizing the only rs-232 port on my PC. I will try to communicate with the controller on NI MAX like you said. I actually do not have the controller yet. I am trying to gather as much information as I can before purchasing it and be prepared to start my experiments asap when it arrives.
(1,766 Views)
Hi JT,
Get the (programming) manual for that device to get all the information you need!
(1,726 Views)
