4D Viewer in LabVIEW
Is someone knowing a nice viewer to display clouds of points in LabVIEW and easily change the viewing angle in real-time by moving the mouse over the control?
I will like displaying an array of points (X,Y,Z Intensity) and see the clouds of point from different angles and also have a customizable color scale based on the point intensity. My array size is about 100 000 points
Patrick
(3,334 Views)
Hi Patrick
I'd Recommend looking @ this example and go from there...
Cheers
J
(3,331 Views)
I've seen this example and NI examples in LabVIEW.  However, I can't find how to apply a scale color based on a fourth variable I which is the intensity of point X,Y,Z.
Patrick
(3,264 Views)
Like I say, use this as foundation.
Maybe play about with some of the properties..
Regards
Jono
(3,260 Views)
