4D plot
I have a question in regards to 4D plot.
I want to plot the following:
X, Y, Z, intensity
By feeding each array respectively into its own vector, meaning XYZ, how can i plot the intesity of the each point, colorwise?
I though that I would have to input the data into the Wvector but it doesn't work...
Ayuda Porfavor!
Thanks N Advance
(5,612 Views)
.Try this thread.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CBC4D111EE034080020E74861
(5,605 Views)
Thanks for the thread...Now I have a question.
Is there a way that I can use a surface plot instead of the parametric plot for the vi that i have attached?
I modified the 4D parametric plot to fit what I needed, but how can i use a surface plot with an wvector input to do the same?
(5,581 Views)
I'm not clear about what you're trying to do, but I think checking out some of the surface plotting examples will help you get an idea of what's possible.  Click Help -> Find Examples... in LabVIEW, then click the Search tab when the Example Finder opens, and search the word surface.  Double click it in the list of words below the search field and you'll find 4 examples.  Hopefully if you see how the surface plotting is done, you'll have a better idea of whether or not it makes sense to use it to view your data.
Best Regards,
JLS
Best,
JLS
Sixclear
(5,569 Views)
My 3D surface plot doesn't have a w input.
(5,555 Views)
(5,550 Views)
