4th-order Spline Interpolation
Can LabVIEW perform a 4th-order spline interpolation or am I doomed to derive it myself? I need a 4th-order spline because I must verify that my first, second, and third derivatives are continuous. I especially can not afford to have my third derivative to possibly be discontinuous.
(3,548 Views)
LabVIEW does have some spline functions under Mathematics » Interpolation & Extrapolation if you have above the Base package (FDS or PDS). If not, you can always search for example code but you might just have to derive it.
Stephanie
(3,530 Views)
I will have to derive it. However, thanks a lot for the advice.
(3,512 Views)
