5.1 to 6.1?
Someone who is not with my company anymore use labview 5.1 and a PCI 6034E Multifunction I/O and create a .EXE file that I which to duplicate in two other system. How can I Use or transfer this files into labview 6.1 installed in another PC?.
(2,503 Views)
If you have the source files, then just open them up and save them. If you don't have the source files, you can still run the executable on any system as long as the 5.1 run-time engine is installed.
(2,503 Views)
