5 second timer
hi,
i dont´t know how to build a timer that delivers a boolean "true" every 5 seconds for running a case-structure.
can anyone give me an advise?
thx
(4,988 Views)
Hi reen,
If you have LV7 or later, the easiest way is to use the express 'Elapsed Time vi'which will generate an boolean true when the time setpoint has been reached.
Hope this helps.
(4,977 Views)
i just have lv6.1
are there other possiblities?
(4,975 Views)
Do other things in the same loop need to run more frequent? If not, you could just use an event structure with a 5 second timeout and place your code inside the timeout event.
If your loop times are arbitrary, but the case should only trigger every 5000ms, do something like in the attached example (LV6.1).
Message Edited by altenbach on 06-20-2005 11:49 PM
(4,962 Views)
Hello
This is created using LV7.0 and down-converted to LV6.1
Not sure if it still works fine in LV6.1 and it may not be exact (ms) but close enough 😛
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,952 Views)
Oops.. duplicate 😛 please see above, thanks!
Cheers!
Message Edited by ian.f on 06-21-2005 04:37 PM
Ian F
依恩与LabVIEW
(4,952 Views)
This could be better for your reference 🙂
Ian F
依恩与LabVIEW
(4,945 Views)
