5 seconds sweep chart
I have a chart displaying a real-time sine waveform with a sample frequency of 300Hz and amplitude 5V.
On the time axis (X) I would like to display 5 seconds of data with the Sweep Chart Mode, how can I do that?
I want the red line of the sweep chart mode to move from the left side to the right side of the chart in exactly 5 seconds, and then start again from the left side.
(3,323 Views)
Accepted by topic author simo28
Set your chart properties for Update mode to either Sweep chart or Scope chart.  Make sure your chart has a history length of 1500 samples (5 seconds x 300 Hz)
(3,294 Views)
I was doing the same thing but nothing was changing Smiley Frustrated
then I just close everything and restart it again and it worked.
Thank you!
(3,276 Views)
