50 khz data acquisition
Hi I am Himmet.
I’m a Test Systems Software Developer in Turkey.
My worked company manufacture to data acquisition systems.Our systems collect 24 bit 250 hz data(mcb 2300 arm 7 labview arm embedded software).can we collect to 50 khz with other software or other microprocessor without dsp or fpga ?
Himmet GENCER
Software Development Coordinator at TDG
himmetgencer@gmail.com
View Himmet Gencer's profile on LinkedIn
View on Instagram
(2,605 Views)
Hi Himmet,
If I understand you correctly, I believe the answer is yes.  You may start by having a look here:
http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/sn/n25:device,n17:daq,n24:cDAQ,n1:7690,n...
You'll find modules at 50k samples/second/channel (S/s/ch).  You should also find things under the PXI platform.  The platform - cost and environment/need - is another consideration.
When you say other software, do you mean other than LabVIEW?  I'd certainly recommend LabVIEW here, and it of course supports all NI hardware, primarily by way of NI-DAQmx.
Hope this helps!
Best,
JLS
Sixclear
(2,565 Views)
