500 microseconds pulse
Hi Everyone,
I need to generate a pulse of 500 microseconds (repeated every 350 mS) and I just wonder if this is possible using the parallel port with LV7.1?  Any sample code will be much appreciated.  Thanks,
Frank
Message 1 of 18
(6,475 Views)
I believe the only way to get sub ms timing is by using LabVIEW RT or FPGA.
Message 2 of 18
(6,456 Views)
This would be a piece of cake using a MicroChip PIC and would be much cheaper.
Message 3 of 18
(6,443 Views)
Trigger a one-shot multivibrator from a much longer pulse (but still shorter that the 350 ms interval). Let the one-shot create the short pulse and software manage the timing between pulses.
Lynn
Message 4 of 18
(6,435 Views)
How accurately do you need to control the 350ms?
Jim
LV 2020
Message 5 of 18
(6,427 Views)
You can also do it pretty easily with most of NI's DAQ cards.
Message 6 of 18
(6,414 Views)
Hi Jim,
Accuracy is within +/-10% . . .
I was planning to use PIC16F877 thru RS232 interface, but I have to be able to synchronize this pulse with a DAQ 34970A to measure resistance.  Here is the scenario:
Drive a relay with a pulse of 500uS and make a resistance measurement (or any other means, i.e current, voltage, etc) to determine that relay did not switch (stays inactive).  It may be repeated at a rate of 350 mS.
Could it be possible to generate this pulse using C# and measurement studio (I will post this question at MS forum also)?
Frank
Message 7 of 18
(6,412 Views)
seing that you have an agilent system, and no PCI DAQ or DIO card, i suggest you follow what Lynn has proposed. a multivibrator is very easy to solder up, and you can drive it from the parallel or serial port.
changing programming language wont make it for you BTW. in Labview, to repeat the task every 350 ms, you can use a timed loop. the inherent software time jittering is expected to be lower than 1%.
... And here's where I keep assorted lengths of wires...
Message 8 of 18
(6,401 Views)
Thanks everyone for your input. . . Frank
Message 9 of 18
(6,363 Views)
Will your relay even actuate with a 500us pulse? What type and or make/model is it?
Message 10 of 18
(6,327 Views)
