500g Load Cell to Control a Parallax Servo Motor
I am needing to create a VI to measure the force on a cantilever load cell to then control the force of a servo motor. The load cell amplifier being used is a ADS1115.
I know I can control the speed and and angle using the Arduino Servo Example in Labview. I am using a Arduino UNO. I have  Pmod NAV 9-axis to cross check the angular velocity and angle of the servo motor, however this uses LINX firmware and the servo uses the Labivew Arduino interface thus I can't have both firmwares on one board. Do you simply have to choose the correct COM in the VI for the two different UNO'?  Is it possible to run them in the same VI as I need to a graph from this at the same time for cross checking.
ARD
(2,361 Views)
here is avi to read ads1115  (2 diferential inputs)
remember have to chanche the bits sended to chance the parameters of working
(1,984 Views)
