5105 Multiple Sessions possible in one application?
Is it possible to group the channels on a PCIe-5105 so one group has one trigger and the other group has a separate independent trigger? Looking at IVI in MAX, it appears possible to create separate logical driver sessions with different groups of channels and different triggers, but I don't know if both logical driver sessions can be opened at the same time on one card in one application, and have them operate independently.
(3,129 Views)
It is possible to set up triggers for multiple channels to reference, but it should be done by a development environment (LabVIEW, Visual Studio, etc) and not in NI MAX. How do you intent to implement this application?
(3,074 Views)
I'm using LabVIEW. What I'm aiming for is to acquire three channels using a fourth channel as the trigger, and another group of three channels again with a fourth channel as a separate trigger. The two groups would trigger independently. However if I open a second session on the same card with niScope Initialize, it seems to stop the acquisition of the first session.
(3,070 Views)
Could you please provide the code for us to look at as well as a screenshot of any errors you are getting?
(3,048 Views)
