5207 lock-in amplifier driver
Hey,
Maybe someone ever wrote a driver for EG&G 5207
lock-in amplifier?
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,724 Views)
If you are looking for VIs that you can use to drive the 5207 with, I found some for the 5210 in the search I did for in the IDNET. Go ahead and try that to see if it works. If it doesn’t, maybe there are few parameters to modify in order to talk to the 5207.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,896 Views)
Hi there, are you succeed to drive 5207 with 5210 driver?
(2,840 Views)
