5465 rf record and playback error when file size exceeding the waveform size
Hello sir,
  Here we are counterfeited with a problem while play back the RF waveform data continuously to and from a binary file.
                We have taken example on RFSG generate waveform from file to be worked with  5645R in NI_EXAMPLE FINDER to get our data played.
Our problem is, when the file size exceeding the waveform size, we are getting the error. Please suggest us on how to play back the IQ file with huge size (say the file is recorded for few minutes).If the file size is less than the waveform recorded, we are getting no errors.
    Kindly support us to get out of this problem.
Thank you in advance.
(3,077 Views)
Hi kmahi108,
1) Can you attach a screenshot of the error you are facing?
2) Which example are you working with from the example finder?
Cheers,
Rao
(3,039 Views)
